Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I thot it was the Starter, as you can see the seal is intact. The oil was splashed underneath the starter and pooled in the area below it. Im thinking the inner primary seal.
The leak is down where the front pulley attaches which is still the transmission. A lot of times the bearing in there will fail which causes the seal to bust.
Did oil leak from the starter it self? The reason I ask is because on my Dyna I had oil leaking out of the starter itself. It ended up being a torn o ring inside the starter not the one on the end but the o ring behind the bearing on the jackshaft
No oil leak from starter. That was the 1st thing I checked. It coming from the trans seal. Now I ask. Is it a big job for a guy who is pretty handy? Or should I take it in?
Depends on how handy you are. If its the mainshaft seal the whole tranny cassette has to come out along with removing the whole primary.
Either the mainshaft seal or the quad seal either way I can keep the tranny in the case. You just need the proper tools to pull the inner bearing race and the the socket to take the pulley nut off
