Tranny stuck?
Tranny stuck?
I changed the head gaskets, put everything back together. took the tranny cover off to drain old fluid. Now, trying to adjust push rods, as I turn the rear wheel ( in 6th gear ) it freezes uo after less than a half turn and I cannot make it move. Also, it seems that the intake push rod on front cylinder is not moving when I rotate the wheel. All the rest od them do move. However, I cannot get a full rotation of the rear wheel. Any ideas whats up?
Of all the stupid things.....
First, I had put the plugs back in, so I thought I need to take them out, to rotate the engine....took them out and noticed something down in the plug hole....a chunk of tissue paper I had stuck in the plug hole when I painted the jugs. Couldnt pull it out with tweezers, so I took the head off again. Lo and behold! There was an entire shop rag in the cylinder! I had covered the cylinders when I had the heads off. Can't say it was entirely my fault, as there was two of us replacing the heads.....OK, I will take the blame.
Of all the stupid things...one for the idiot award, I suppose. Everything turns now, push rods work fine. I am happy that at least I found and fixed the problem. Please, dont flame me! LOL
