Replacing drive belt that broke
the drive belt on my 2000 Ultra classic trike broke last week. 102575 miles isn't bad for a stock belt right? Anyway after calling around the area it appears there are no independent mechanics that work on harleys. And I don't have 1K to give to the dealer to fix it. So I'm going to fix it myself. I have the service manual and most of the tools already, And while I'm no master mechanic I think this is something I can handle.
Anyway as this will be my first time taking off the primary i figured I'd ask for any tips/tricks any of you have used. I figure after 100k miles I should probably replace any bushings and seals while I'm in there. Should be fun.
I do have a couple of other suggestions.
1/2" drive is usually not big enough to break the trans pulley nut loose. Rent a 3/4" electric impact wrench. You will also need the long socket and donut.
Replace all the seals behind the inner primary while you are at it.
Replace the inner primary bearing seal and race.
Check swing arm bearings for wear; might as well replace them and the rubber "donuts" as well.
Inspect both trans and rear wheel pulleys; might be time to replace??
All Very good suggestions and I'll take whatever help I can get. Little did I know that the Lehman trike kit on the back is already more work than taking off the primary will probably be. the sprocket in the rearend is encased in steel so slipping the belt around the axle wasn't going to work. I had to completely drop the rear end out and then still couldn't figure out how to seperate the 2 halves of the rearend housing to put a belt on.
So after scratching my head for a few hours and trying everything I could think of I called lehman since I don't have a manual and the one online does not cover it. and left a message with the technical guy. surprisingly he called me back the same day with an answer. seems there are 2 false bolt holes in the housing that you put a bolt in and crank it down to seperate the two halves, something I never would have thought of. so Now i have it apart and cleaned up (100K miles of grease adds up) and ready to go back together and back under the trike. (i'll add pictures later in case anyone else needs to do this in the future). Once I have the rear end back in I'll start on the primary. Now I know why they want to charge 16 hours labor to change the drive belt on a trike.
Thanks for all the suggestions I'll let you know how it goes from here.
