Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Anyone remove the damper spring and the skinny friction plate and replace them with a steel plate and friction plate? A stock extra plate if you will? Would the clutch adjustment be any different?
I think the damper spring is needed. The bike should have one narrow friction disk a seat metal ring then a damper and on top the regular plates. My clutch pack is apart right now if you need something specific I can check for you. It's going back together tomorrow. I don't know for sure but I think you want to leave they in there.
