Easy boy Clutch Kit by Burly
There are quite a few devices that do much the same job. Be aware, however, that the Evos have very little 'spare' travel on the clutch cable and you may find it difficult to adjust and operate the clutch properly if you fit one of those.
There are two alternatives in my experience with my 1990 Glide: 1. use a Diamondback clutch cable, as I was suprised how much smoother and lighter that made my clutch; 2. consider a AMP EZ-Pull. More expensive, but should give better results.
