Metal flakes in transmission oil
I pulled off my trans cover on my 2007 FLHTC for the first time to replace clutch cable and noticed quite a lot of metal shavings in the cover and around the bottom passages. I do routinely chane my transmission fluid and there is usually a decent amount of shavings on the magnet as well. I understand that having some is normal wear and tear but how much should or shouldnt there be? I only have about 8000 miles on this oil and there is more flakes than I have seen previously. The bike seems to shift normal and it doesn't make any unusual noises. Got almost 60k on it.
