Derby Cover
Derby Cover
03 Dyna Super glide just did my 10,000 mile fluid changes. Have two problems that I am hoping have the same fix. When I torqued the derby cover bolt #2 will not torque. I can hand tighten but as soon as put a torque wrench on it the bolt just spins. I swapped bolts and same bolt will tighten in different position but all bolts will only hand tighten in position 2. Second problem is I a I am getting a rattling sound. The rattle is worst at 3k rpms but is present all the time. Only time I am not hearing it is when accelerate (pipes may just be drowning it out). So 1, how do I fix the untorqued bolt and 2, is this probably the rattle problem or is it probably unrelated?
Thanks in advance.
Thanks in advance.
