6 speed trans leak
Luck of the draw; **** happens. Find the leak, fix it and ride on. There were some noise issues with the early six speeds but none sense. I still ride the old five speeds and they are bullet proof.
Obviously since you have a leaking 6 speed, they all must be junk.
If you need some help, we`re here.
If you came to whine....
Go to the whiners section.
I think you are getting hosed. I have repaired several leaking transmission although none were six speeds (the five speeds can leak too) and never had to pull the transmission to make the repair. Call me a cynic but something doesn't ring true with the dealers diagnosis. You need to ask some questions; I would start with the obvious.
1. Where is the leak coming from?
2. Why does the trans have to pulled to stop the leak?
There is no reason to remove the transmission from the motorcycle, unless the case is being replaced.
600 sounds about right to replace all seals and gaskets, if you are paying someone to do the job.
