Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
The big debate at work is wet or dry clutch. Do you soak the clutch plate in oil before you install them or not? And how do you tell the difference between the two types of clutches in a 1979 FLH? Thanks for any feedback. The manual is not very clear !!
