Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
one peice jackshaft vs. stock setup
Old 08-02-2014, 07:13 PM
tourglider1985's Avatar
tourglider1985
tourglider1985 is offline
Default one peice jackshaft vs. stock setup
hey guys and gals.. just wondering which would you prefer on starter jakshaft , a one piece design like the allballs or the stock setup?
is the one piece just as reliable as the stock shaft?
any input would be great..thinking of trying the one piece ,but I do not want to waste my money if there not all that great..
Old 08-02-2014, 07:26 PM
dawg's Avatar
dawg
dawg is offline
Received 3,013 Likes on 1,735 Posts
Is your current one in need of repair/replacement?
Old 08-02-2014, 08:35 PM
tourglider1985
building a custom and piecing a primary together,,just wondering if the one piece jack is a good piece or more trouble than its worth
Old 08-04-2014, 11:59 PM
tourglider1985
wow,,no takers on this one?
Old 08-05-2014, 04:37 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
My guess is that not a lot of folks have had trouble with the stock design to warrant a response. Sometimes no response IS the response.
I have heard of people having trouble with the stock set up on high compression motors but they didn't have compression releases. ACRs or manuals (that you use all the time) should do the trick.
Old 08-05-2014, 08:01 AM
tourglider1985
thanks for the reply
I do have compression releases on the bike I am riding currently.im also run ning an ultima belt rive , and the one piece shafts look a lot like the jack on it..the ultima is one starter grinding SOB,its embarresing to be picked out the crowd for that one, kinda like trying to pull out and green horning your engine...lol
I just wonder if the one piece has the grinding issues or are they a good smooth engadgment like the stocker
Old 09-04-2014, 10:26 AM
tourglider1985
well I purchased the one piece jackshaft for my flt...so far so good ..no grinds or engadgment probs..
hopes this helps anyone else with the same question
BikeAriz2
Exhaust System Topics
04-18-2011 08:22 PM
ben67zl1
01-23-2009 04:05 PM
Turul
07-19-2007 01:10 PM
Quick Reply: one peice jackshaft vs. stock setup
