Looking for some guidance
Just picked up a 2011 FLTRX w/ a 103 with 25k on the clock I have noticed that in the lower gears, 1st and 2nd, when slowing down in anticipation of stopping for a red light for example. When I roll off the throttle and pick it back up again because the light changed I get a single clunk from what sounds like down low. No other issues when either down shifting or running up through the gears. Bike pulls strong. Any thoughts on what this could be?
Sorry so slow getting back on this thread! Cannot speak for the "cush drive", but the compensator is not too hard to check out. Pop the outer primary cover(drain first of course), and remove the compensator bolt per HD Service Manual. Now you can pull apart the compensator parts and inspect for damage, look at the compensator spokes for damage, check out the compensator retaining nut and where in goes inside the compensator for wear and obvious lack of lubrication.
If it looks bad, replace it with the new 2014 SE version:
Wayne66866
08-07-2013 11:32 AM
