FXR4 leak from inner primary
I think I have found the leak which has been throwing oil all the way to the back wheel. I bought the service manual but can't identify what I'm looking at. If someone could point me in the right direction I would appreciate it.
This is the rear of the inner primary just in front of the kick stand. The bike is a 2000 FXR4 with an 80 cu.in. EVO engine.
That looks like the back side of the threaded portion that supports the lower bolt for your primary chain adjuster. Maybe it was bottomed out by a too-long bolt and got a crack reaching to the outside in the process? (See where the lower bolt hole would be in this pic?)
I guess the best thing to do is drain the primary and get the chewing gum cleaned out then see what the hole looks like. I've never worked on this bike much except getting the float unstuck on the carb. Does this look like something I might want to try or should I leave it to someone else who is supposed to know what they are doing?
I don't understand why the bike would have needed the inner primary worked on with just 10,000 miles. I did have the dealer replace the voltage regulator after a near death experience on I-459, but other than that just a 5,000 mile service when I bought the bike (with 9,000 miles on it), tires, brake service and a change of the outer primary gasket which was probably the leak I still have and not the outer primary.
It seems like every time the weather is nice the bike is having issues.
Thanks for the help so far.
I'm going to give it a closer look today to try and find another place the fluid may be leaking, then I'll clean the underside. If I don't see a leak while it's cold I'll take a short ride to see if I can zero in on the leak. I'll post an update when I know more. I did hear from someone who had a similar glob of silicone in the same place and it wasn't a problem for him.
Here is an update on the leak. Below is a photo of the leak reappearing overnight, so that is where the fluid is coming from. The silicone plug is factory work, I found a similar plug a few inches above the leak and they match the location of the chain tensioner. I will remove the outer primary cover and the tensioner, clean out the old plug and replug the hole with fresh silicone. Thanks for the help and suggestions. I'll be back with an update when I'm done or if I need a little more help.
