Baker bearing replacement '06' Dyna
Hi guys,I have a 2006 Dyna Wide Glide with 24,000 miles.The inner primary bearing was replaced at 16,000 miles and has now failed again.I know about the missing dowel problem.I would like to upgrade to a Baker sealed bearing,new compensator/rotor and chain tensioner.Anyone know the part numbers and best place to order them from?Also as I understand the 2006 inner primary is already drilled for the 4 dowels but not the transmission case.So I assume i only need to purchase the transmission case and seals and gaskets.Any help would be greatly appreciated.
