Primary found with no oil after service
OK...after replacing my belt, it appears my local dealer in Branford, CT failed to put oil back in my primary case. After a hundred miles or so I started hearing a metal to metal clinking noise. I opened up the side viewing hatch only to discover the chain bone dry and no oil in the primary case.
So...how bad is it? Advice and thoughts welcome.
2003 Road King Classic
63000 miles.
63000 miles.
100 miles hopefully didn't hurt anything. My BIL had his 1k service done at local dealership on his obviously new Tri-Glide and they never refilled the primary. I called them up and told them about it and they said to bring it back and they would dump a quart in. I told him I already did but they could give me a quart to replace the one I put in and they said no, we cant do that. Apparently they can charge for oil and not put it in but they cant refund anyone for something they charge you for but fail to do.
Had that happen to me as well. Had them put on a chrome inner primary before delivery of the bike. After a few days noticed a leak between the inner primary and the motor. Took it back, had it "fixed" a couple days later there is the leak again. Well I figure the 3rd. time's a charm right. Bring it home and notice a bit of a whine coming from the primary. Open the cover and you guessed it bone dry. Guess that's one way to fix a leak. Fortunately I am only 15 or so miles from the dealer so don't think I fugged anything up. This was back in 08 so I'm sure it would have shown up by now. However my compensator seems to be making more noise now but that' a story for another day.
63000 miles.
63000 miles.
I got to Sioux falls Harley when they opened Monday they pulled primary NO OIL!! What!!!! 1000 mi no oil. Chain was stretched so max adjustment just kept it from hitting housing ( which was the noise I heard).
They had no chain in stock, clutch looked ok and so did comp.Was it a miracle or just luck Had amsoil in before they serviced it. finished trip and brought back to indy who replaced everything no charge.
I service my bike myself these days. Don't need surprises like
