02 Sportster clutch problems????
I have an 02 standard with 14,500 miles. When shifting out of neutral it will grind the gear 3 out of 5 times and when riding it will give hard shifts sometimes as if you weren't using the clutch.
I figured it was time to do an adjustment. When I went to roll it around the shop it was in gear and pulling the clutch didn't help until I rolled it back and forth a few times and then it was still hard to push.
I jacked it up, put on stands and did the adjustment procedures. Put it in gear and pulled the lever and no change, you could not spin the tire by hand. I tried turning the screw 2 turns tight too a couple a turns loose, no difference.
Any Ideas????
Thanks
Any Ideas????
Thanks
