Clutch disengage
Clutch disengage
I read a bunch of similar threads but at the end of them it's a newer bike.
I changed my handle bars to mini apes so the total move up was 5minches nothing much with a 42" clutch cable.
But now the clutch won't engage. While pulling the clutch in and starting to back up or move forward. (Engine off) the bike is in gear still. It's an 89 sporty so it doesn't have anything fancy.
Do I need to do more than loosen the cable? Why does it stay engaged?
Thing is I didn't do anything. Clutch worked fine one day. Changed bars and just put the clutch back on the bars. I'm guessing that was my folly I saw the sticky about adjusting so I can tear it all down and start from scratch. Just thought that was weird it didn't work just because it's 4 inches higher in the air now.
Check the routing of the cable, as if it is stretching around something it may affect operation. You did do something, it may be that 'only' being 4/5 inches higher is a smidgin too far! Once you are happy the cable is free and easy, from lock to lock, do the clutch adjust procedure and let us know what happens.
I can see the clutch engage when pulling the lever if I leave the derby "cover" off more like a small Cap on my bike. I have the dumb climber book and I compared the sticky notes with it while under work. But when I shift to 1st or 2nd roll it to lock It in then I press the clutch lever in it won't disengage the clutch allowing it to roll free. I haven't started it or tried to engage while engine running for fear I would have to kill it and apply the flinstones brake.
Any thoughts? About to rebuild the clutch and add that to my harley self mechanic time.
Figured if I pull the clutch lever in the clutch is engaging or removing pressure from the drive train. If the cable was too short it would just stay in neutral all the time.
