Clutch replacement help?
(2012 Street Glide) I'm waiting on my 4+ clutch cable to arrive (current cable just snapped at the ring on the end!). I've got the cable removed from the fairing, and when the cable arrives I'll be removing the trans cover, etc, etc. Here's my question. I only removed the upper heat shield from the rear pipe for clearance. I can get to the 2 bottom trans cover bolts but, will I have enough clearance to remove the bolts? I know that some of the bolts are longer than others. Will the exhaust get in the way? Don't want to remove them if I don't have to. I've attached pic to help.
Thanks for the help,
Jeff
Jeff
