kicker moves when bike is pushed
Just bought a bike with a revtech 5 speed transmission and kicker. Not sure if the kicker came on the revtech originally or was one of the addon kits from somewhere. In any event, here is my problem. The kicker arm does not move freely in either direction, it feels locked tight. It does move however if I put the bike in gear and pull the clutch in so I can roll it around. It moves just like a clock and I think would just keep spinning if I kept pushing. I'm trying to figure out if I should try to pop off the cover and see what's going on under there or if it's a sure thing the whole trans is going to need to come out.
The gears were definitely sticking. I took off the kicker cover and saw the gears stuck together...
Looked pretty awful. I pulled the trans and checked it out. When I took the top cover off, I was surprised that actually the rest of the trans looked in much better shape. I cleaned up the rust, put everything back together, and the kicker was functional. I realize the tranny is probably going to be no good (all that rust must be getting into the bearings), but after putting the bike back together and starting to adjust the clutch I heard a pop. I went around and checked and the kicker was back to being stuck. I pushed on the clutch basket and popped the main shaft back in place. Now the kicker is functional again and working correctly as long as I don't push the clutch out. It seems like the pressure of the clutch pulled the entire main shaft to the left and pulled the gear into engaging with the kicker. What is supposed to keep that from happening in the tranny?
grimreaper666
03-05-2009 12:20 AM
staged67gspwr
21
04-04-2006 11:32 AM
