Helmets
RE: Helmets
I don't know if this helps or not, but I recently purchased a DOT approved half helmet from "Head Trip" out of Orlando, and its gott'a be the lightest DOT approved helmet I'ver ever seen. Its constructed using kevlar and carbon fiber. The energy absorbing layer inside the helmet is only about 1/2 the width of a standard DOT approved helmet using foam, but it has met the DOT testing criteria.
The helmet fits well and is comfortable enough. I can't say that I really like the fastener arrangement for the chin strap, however. Its a buckle of sorts and is often difficult to latch underneath my chin once the helmet is on. I think I woiuld prefer a simple nylon strap routed through two D rings.
Anyhow, do a google search for "carbonfiber motorcycle helmet" and take a look. (They make novelty helmets as well, so be sure to click on the "DOT" button.
It ain't cheap at about $175 and up, depending on colors/graphics, etc.
RE: Helmets
My friend has one of these NXT helmets. He says it is very comfortable and does not slide back on your head like some novelty helmets. The only thing is that you have to CAREFULLY measure your head so as not to get the wrong size. He had to send his first one back to J&P because he did not follow the directions. The inside of the helmet looks pretty good, nothing special, but it sure is a thin helmet. I will probably end up ordering one. The only thing he does not like, and it is a problem with most helmets, is that the stracp tends to be uncomfortable after a few hours under your chin.
Here is their web site: http://www.nexlsports.com/
RE: Helmets
I have read the web info about these helmets and they seem like the helmet to have but I'm like Ironhead and if I'm going to pay that much for one I want to know if they ride as good as they are suspose to.
Also, for general info if a helmet is DOT approved it does not neccsarily mean it has been tested by the DOT. The DOT gives the approval then test the helmets, I'm not sure that they even test all the helmets that have the DOT sticker on them, the DOT web site gives the info of which helmets have been tested and pass or fail and why.[:-]
RE: Helmets
Just in case you happen across 1... 01 and 02 model helmets have been recalled.
http://www.nexlsports.com/index.php/cmd/recall
RE: Helmets
I bought a DOT approved 3/4 helmet from Jafrum for $22. Looks and feels just like the one I bought in '68 when I got mu first bike. It is important to follow each manufacturer's sizing chart though. If the site you're wanting to buy from doesn't have one, find it on another site before you order. In some helmets, I'm a large...in others I'm an XL. From Jafrum I was an XL and it's a nice tight fit. I figured for $22 I couldn't go too wrong and will ultimately keep it for a spare passenger helmet. I'm looking at the Nolan full face N100E, but wish I could find a place to try one on.
BTW, my local H-D dealer, carries Harley's and HJC. They told me that the Harley helmets are made by HJC. Anyone have any info on this?
