OKC to Lubbock
Man I see your dilemma. Any way you go isn't going to be the most scenic. Well unless you like seeing a lot of nothing except maybe some windmills. Are you going and coming through that area? if so, go one direction going and the other coming. If only doing it once, I would have to try the Lawton, Altus, Childress, Paducah, Floydada way would be the way I went. But that may be more because I"ve been the other way before (albeit it was in a cage). Enjoy your trip and let us know which you decide.
The fastest way would be I-44 south to Wichita Falls and then west on Hwy 82. If you're doing this in the summer it will be very hot and non-scenic. Maybe consider west from Iowa over to Colorado and then south toward Tombstone. At least through most of Colorado the temp will be a little more tolerable.
