Remote garage door opener - 2015 CVO Limited
#31
I have a '15 CVO RGU. hooked up my door opener..... it works, albeit the distance is short. Here is my complaint. When I crank the bike and the headlights automatically blink/dim the opener opens or closes the door. This could be a disaster if bike setting under door and started.... door closes on bike!!!!!!!!!
#32
The built in receiver on your operator and the one HD supplies with the CVO may interfere with each other if they are close to each other. This will reduce your range. The most convenient and likely place to plug in your new HD receiver is in the outlet on the ceiling next to your operator, but this is also the most likely place to cause interference. If you plug it in there and see a marked difference in the range of your remotes, try plugging it in to an outlet 10 feet away and run the wire to the operator from there. Not all GDO's are affected due to different frequencies being used, so you may not experience any difficulties at all.
#33
cdestuck
Screamin Eagle CVO Models
09-04-2016 09:08 PM
