cam choice suggestions for 2014 cvo upgrade
Old 10-19-2014, 02:26 AM
pharough's Avatar
pharough
pharough is offline
3rd Gear
Default cam choice suggestions for 2014 cvo upgrade
I have a 2014 CVO Breakout with vance and hines 2 into 2 exhaust. I want to put in high compression pistons, 53mm throttle body, larger injectors, and bigger heads. I am trying to decide on the cam. I am torn because I dont want to have to rev the bike high on initial takeoff as I have been told would happen with a bigger cam. The 254E cam has been suggested for quicker acceleration. I am open to suggestions. I have even thought about leaving the cams alone. I dont mind sacrificing top end in order to get maximum power and acceleration from 0-100. For now I want to stay with a Harley cam for warranty issues
Old 10-19-2014, 06:10 AM
tully_mars's Avatar
tully_mars
tully_mars is offline
For bigger cams typically you need to add some compression to get them to perform especially at low rpm. If you build it right low rpms will be a lot of fun. There are better cams than the 254e so talk to some builders and folks that are actually running the cam they recommend . HD cams are EPA compliant so they will limit performance since the MOCO has to meet the standards set.
For me, i am a Woods fan and have Tw-222s in my bikes, lots of low end. Talk to Jamie at Fuelmoto and they will steer u right.
Old 10-21-2014, 07:57 AM
slammed05fatty's Avatar
slammed05fatty
slammed05fatty is offline
i agree w/ you but he wants to stay w/ harley cams so fuel moto wont really be helpful.
if you want best performance i would steer away from harley though but i can see your side of it
Old 10-29-2014, 08:35 AM
Boost's Avatar
Boost
Boost is offline
The SE 259E is a good cam for what your looking for.
Look at the SE 110 stage III kit. Comes with the SE 259 cams, pistons, gaskets, tuner and pushrods for $1,259. Potential for 110hp and 114 tq with stock heads. More with head work....
Old 04-07-2015, 10:14 AM
SmokeEm's Avatar
SmokeEm
SmokeEm is offline
All of the 110" CVO engines come with the SE255E cams so if you were wanting to stay with the H-D parts the next cam upgrade would be the SE259E which is also available as a kit that includes the 10.5:1 pistons and some other parts as well. My recommendation is to talk to a tuner close to you and let them assist you in selecting the parts that will work best for your budget and expectations. I know there are several that are near you, GMR Performance is in Ft. Worth, TX. The stock heads aren't that bad but the best man in the business for cylinder head work is T Man Performance. Just remember, all the performance parts in the world won't mean anything without a good tune. The tuner is the key. One of the best tuners around is Doc's Performance in Minneola, FL.
Wmitz
Engine Mechanical Topics
05-17-2014 08:47 PM
Ryan8585
04-23-2013 12:54 PM
jakerbaker01
Exhaust System Topics
11
08-31-2011 07:15 PM
speakerfritz
08-19-2011 03:10 PM
DCRANER
05-09-2006 12:59 PM
Quick Reply: cam choice suggestions for 2014 cvo upgrade
