Does anyone know if there are HD fitted bag liners for a CVO? Looking in my 2010 P&A catalog they list them as 09 and up. The 12 CVO RG has stretched bags.
Also does the radio antenna have to be relocated to install the 4 point docking plates? Thanks
I had fptted liners in my 2007 cvo ultra classic and i have fitted liners in my 2014 cvo limited.Check Ronnies HD and put in your bike,it will show the part numbers and the price.
I'm confused.......are you asking about the carpet like liners inside the saddle bags or are you talking about the soft luggage that you pack and then put in the saddle bag?
Thanks, I looked on Ronnies but it wasnt to clear, maybe Ill recheck again. The cvo ultra liners are a regular shaped saddlebag. The roadglide custom has stretched saddlebags so the bottoms fit differently. I cant go and by anything yet because my lovely wife has requested to sell my 07 rg before I start buying things for the CVO.
My 2010 FLHXSE has stretched bags. Bag liners were included from the factory but they are the standard sized ones. I don't think the MOCO makes liners specifically for the extended bags, but I could be wrong (happens frequently).
As to the 4 point docking and antenna question. From the install instructions: FLHXSE and FLTRXSE Models: Position the antenna mounting bracket (C) to the left side docking plate (1). Install the screws through the docking plates and fender covers, and into the threaded holes in the frame extension. When I installed mine I added a hidden antenna and eliminated the whip. Much better look IMO and the radio still works OK.
Thanks YB, do you have the correct fitted liners on your bike? I see you have the stretched OEM bags. Im going to be highly disappointed if moco cannot supply correct fitted liners for the cvo bags. just sayn'
Thanks for the tips on the antennas, was just going to find a suggestion for a hidden one to install when I hook up my xm.
I am not aware of any new liners. I do a lot of research for folks and myself but never ran across anyone making something different.
I put my tool kit and rain ware in the extended part.
The antenna does not have to be relocated. It is not in the way for the 4 way docking.
