help got the wrong manual
I recently picked up a 2012 FLHXSE3 and when I got the bike I also purchased the manual.
Tonight when I went to look for how to remove the lowers so I can remove the head pipe, I realized the manual I got is the electrical service manual.
Would anyone be kind enought to tell me the torque settings and sequence on the head bolts for the header? I could also use all the other torque settings on the exhaust.
Any help on the lower removal would be appreciated as well.
I would also be willing to purchase a 2012 manual!
thanks
thanks
rear muffler fastener 96 - 144 in-lbs
muffler clamp 38 - 43 ft-lbs
crossover pipe hanger bracket 84 -132 in-lbs
exhaust flange adapter nuts, initial 9 - 18 in-lbs
exhaust flange adapter nuts, final 100 - 120 in-lbs
exhaust side bracket carriage bolt 20 - 25 ft-lbs
exhaust crossover pipe clamp 25 - 30 ft-lbs
crossover support clamp to transmission 14 - 18 ft-lbs
exhaust heat shield worm drive clamp 20 - 40 in-lbs
tighten the bottom rear nut to 9 -18 in-lbs. tighten the top rear nut to 100 - 120 in-lbs. tighten the bottom rear nut to 100-120 in-lbs
tighten the top front nut to 9 -18 in-lbs. tighten the bottom front nut to 100 - 120 in-lbs. tighten the top front nut to 100-120 in-lbs
tightent the side bracket carriage bolt
tighten crossover pipe clamp
tighten crossove support clamp
Thanks.
