110 sleeve thickness
Old 02-01-2015, 05:08 PM
dgdamore's Avatar
dgdamore
dgdamore is offline
Originally Posted by OldEnuf2NoBtr
You can overbore the cylinders .060 to get to 113". Any more than that (117)and you have to split the cases for more work.
You're close but not exactly correct.
110 engine cases have been modified from the factory to accommodate (and use) a longer stroke crank.
The SE113 engine kit uses a 4.060 cylinder with a significantly thicker sleeve than the stock cylinder which is designed to be used with the 96/103 short stroke crank.
The mods done to 110 cases to accommodate the longer stroke crank prohibit them from being used with the thicker sleeve 4.060 cylinders used in the SE113" kit.
FWIW, a competent engine shop might be able to modify 110 cases to accept SE113 cylinders because these are the same jugs used on 120Rs which uses a longer stroke than 113's. (This is why SE113s are so much faster revving than 120Rs.)
To answer the OP's question... 110's are 4.00 113's are 4.060 and I think service spec on any stock HD cyl. is twice over which is .040.
Of course this is all just what I've been told.
Old 02-02-2015, 08:07 AM
jbrelr21's Avatar
jbrelr21
jbrelr21 is offline
that is what I was looking for 110 cases are differant some how than 103 and 113 cyl are not compatable. The 40 thou thing is way under with some oem. 88 cyl are going to .125 overbore which is 95" and 97 " is being done. I have 110 cvo and 4.06 new cyls bought originally for my fxd but the thing runs too good to take it apart. I was thinking of using them on my 110 but the SE catalog says no go. Better save for a DD7 instead anyway. Keeping this bike forever.
Old 02-02-2015, 08:57 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Suburban Harley-Davidson
139 North Main St.
Thiensville, Wis
1-262-242-2464 has all the Mahle 110-113" pistons you want.
We buy them, from them, with a 9cc dome from their Speed Shop.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
leafman60
01-28-2018 06:51 AM
Aggressor05
Engine Mechanical Topics
13
12-17-2016 04:41 PM
sharkey
09-28-2015 11:13 AM
rcaddell
06-04-2012 04:51 PM
speakerfritz
09-12-2011 06:21 PM
Quick Reply: 110 sleeve thickness
