Picking up a 16 FLS S, school me on the 110 motor
So I'm picking up a Slim S next week. Bike arrived at my dealer today. I'm stoked to get it but no little about the performance of this motor and what I can get out of it. Posting here as I figure you fellas are more familiar with the 110.
Performance wise what is a must do? Obviously I plan to have pipes added straight off, actually they are already at the dealer in stand by. All my previous bikes I've added pipes, a AC, TTS Mastertune, and a Dyno run. My dealer is telling me that is not necessary with this motor. They say just adding pipes is fine as these bikes ship from the factory with Stage 1 and that know tuner, Dyno, ECM flash is necessary.
So just looking for advice and opinions. Thank you in advance.
Thank you for the replies. That is exactly what I was thinking. What he was saying went against everything I had thought. I have always run a TTS, but he was trying to say not needed.
So then I can get a Pro Tuner from the dealer for a song when I get the bike. No experience with them. Go ahead or stick with my Indy shop and a new TTS? I'm open to giving it a go because of the price difference, but not at the expense of performance.
If you're going to go with a flash style tuner, like the SERT or TTS, that means putting the bike on a dyno. That means running it up to high rpm levels...which is not something you want to do on a new bike. The dealer that I have had my bikes dyno tunes done takes about 4 hours to get done. They prefer a minimum of 1000 miles on the bike.
I bought a CVO limited and had Rineharts put on it before I took it home, but it was only because the dealer had a map already for Rinehart Slimlines on a 110 so I had a decent base map to operate with "out of the box". I just took it back in yesterday to have the 1K service and the full dyno done.
So...you can put a 1000 on it and then decide, or if you are set on new exhaust right now, and the dealer can put some sort of a workable base map on for you to get you through break in...either would work if you staying with a flash type tuner.
If you are looking at Vance and Hines, I have heard good things about the FuelPac tuner, which is more of a "do it yourself" thing. I am sure you could get the boys at V&H to give you a map close enough to start with if you choose another exhaust system, but I would check with them first before dropping the money.
Well, Nevermind. Slim S came in. Looked at it. Didn't really care for the color, then left on a new 15 Street Glide Special. Bought it for the same money as the Slim S and took advantage of HD's .99 financing on leftover 15 touring bikes.
Thank you for all the replies though.
You made the right choice!
Congrats on the Street Glide.
YB
