Anyone know of a blow-by kit for this specific SE Air Filter?
As the title states and this is stock on my bike. I'm coming up with my own ideas but looking for anything that has been done or someone knows about.
This is what I found after taking mine off so I know I need/want to do something.
Thanks for any insight.
The hot air and oil mist sucked into the engine increase deposit build up and reduces power by about 2 hp. The engine needs cool air not hot air vented from the inside of the engine.
A catch can is worth the cost and effort. Some sports cars come standard with them because of their performance benefit.
I will take of picture of my 13 Street Bob 103 with 7,700 miles on it and post it. It had run E10 fuel which is cleaner burning and had the gas treated through three tank treatments at three thousand mile intervals. It is a lot of build up on the pistons, heads and valves.
I am in the process of rerouting the vents on my bikes.
I pulled the engine because I dropped a 120R into it.
Just taken apart for picture purposes. The gasket, chrome intake and filter have been removed. You are looking at the black cover over the throttle body. The breather bolts drain into the black cover which has drains that drop right into the intake.
Received 3,939 Likes
Both of the kits at the following links will fit...they are actually the same kit with the exception that on use black hose and the other uses black hose with a stainless steel braided sheath.
http://www.dkcustomproducts.com/DIY-...DIY-BH-BRT.htm
http://www.dkcustomproducts.com/DIY-...IY-SSH-BRT.htm
Would the plan to be drilling the outside of the cover for the fittings? I understand the idea of blocking the drain ports once placing the new fittings. My initial idea was to have the new ports under the cover but there is not enough room because of the throttle body electronics.
Also drilling the outside of the cover will have the drain fittings at higher angles that aren't as desireable as having them at the most bottom based on gravity feed and is the his okay?
I'm still obviously working on this and I'm coming up with a couple options that require no drilling. I'd love to see something with this exact kit but I have found nothing.
tripleb1911
09-19-2014 03:53 PM
