2016 110 cvo
Doubt you will find a canned map or tune for that combination.
The 259E is a very good came, but likes more compression than you have, its best with 10.8 or more compression. It needs the compression to keep good torque at lower RPMs and to make HP at the top.
CFR mufflers are hard to tune, they do not have enough back pressure, and are not good for low end torque. Best sounding muffler in my opinion, however they do not perform well.
that would allow you to choose cam and exhaust map.
Was the 110 upgrade kit (SE259 cam, 10.5 pistons, clutch spring, Super Tuner) installed? After verifying the cam timing is OK, ( simple compression test with ACRs disabled), sell those mufflers, install a set of Crushers, and retune it. A road trip to Wide Open Cycles in Fredericksburg, MD would be well worth your time & $.
Crusher mellows are a good choice for mufflers
Then again, I didn't use the HD 117 kit, other than the cylinders when I built my 13 CVO King for the second time. I would have lost power with the 117 Kit over my built 110.
