pro 110 performance upgrade kit
i have a 2011 street glide 96ci that i just upgraded to a 110ci. while doing the upgrade i had the dealer install the pro 110 performance upgrade kit which include se 10.5 high compression pistons, se perfect fit push rods, se 259e cams, se high performance inner cam bearings and se super pro tuner. i have rinehart true dual exhaust and a se heavy breather. what kind of numbers should i expect to see on a dyno? my current numbers are 101.19 hp and 105 lbs torque. should i expect more from this setup or are my numbers about average. if not should i take the bike back to harley for them to re dyno the bike? any input will be greatly appreciated. thank you
