How are you making your 110 kick ass?
How are you making your 110 kick ***?
Anyone try the Screamin' Eagle Pro 110 Performance Upgrade Kit? (27548-10A) Anyone try different heads, MVA, 110+, etc? I'm torn between pulling my 110 in favor of a 120, but it seems a 110 upgrade kit with some additional mods could make some serious HP and torque for a lot less $$$.
get a hold of Don Dorfman here...http://deweysheads.com/
hes a straight shooter and wont miss lead you on what works best...
paul
paul
I sent my 09 to Bob Wright, R&D Performance in Watertown MN. I posted a while back all the things I had done. Now turns 125 plus HP and 126 LB torque. I just had an altered map sent to me for the tuning because I have a detonation problem at high temps. Not bad just bugs me a little. I installed the Crusher exhaust and this morning installed the quiet baffles. The system was designed not to require a map change by altering the baffles. Sounds great and now I can get through town without setting off all the car alarms.
I have balanced,trued, and welded the flywheel, H-beam rods, se high comp pistons, mackie heads/with bigger valves, mackie.598 cams, 58mm throttle body, runs great, also use the rev perf ems for fuel management
