Whats Your 110 Dyno Numbers
#131
#132
I bet you'd get a lot better numbers if you dump the race tuner, put on a power commander and have someone tune it. I'd have expected a lot more torque with all the changes you've made. Just my opinion. Every one I've talked to that tunes MC's will not touch HD tuner, and said that HD puts the closest match on and doesn't actually tune anything. Almost pointless.
#133
#134
All of the motor work and tune was done back in 2011. I am not the original owner but he had the motor torn apart and everything done after the 500mi break in. Not sure what was around back in 2011 other than race tuner but I can probably change the tuner and get more out of it. I just bought the bike back in march with 7700mi on it.
#135
#136
#138
Just did some winter mods on my 13' CVO Ultra. 585 S&S cams,complete cams pro magnum lifters,adjustable pushrods, kibble white .630 beehive valve Springs, heads milled to raise compression to 10.5:1, pcv tuner, decat/modified front header, CVO mufflers with 2.25 big Louie baffles. 109.5hp/122ft tq
#140
2013 seuc
134hp/135tq
Just got motor work done @ Fuel Moto. I shipped the bike to Jamie and staff. I should have the bike in a few weeks. Will post dyno sheet as soon as I get it.
113 Big Bore Kit, 58mm TB, 11.0 Compression, Woods 999-6 Cams, CVO CNC Head Porting, HP Inc 5.3 Injectors, AIM Variable Pressure Clutch and Jackpot Hi Roller Mufflers. Whew:-)
