Whats Your 110 Dyno Numbers
#171
#172
I have a 2012 FLTRU Road Glide Ultra that originally came with the 103, but I had the Big Bore 110 kit put in as part of the original purchase. I put the V&H power duals/High Output combo, the SE110 heads, SE255 cams, SE Heavy Breather intake and the SERT. That set up netted 97bhp/112 Ft/lbs.
Back in July, I had trouble with the cam tensioners that resulted in a full Long Block engine replacement. I was able to negotiate a cam upgrade to the SE259E's. I got that dyno'd after the break in and got the 112.91 BHP and 122.78 Ft/lbs seen below. It's a lot of fun to ride.
I know there is plenty left on the table here. It's a canned map and a full tune would pull better numbers.
#173
With our Stage I CVO Headwork/58mm S/E t/body and S&S .570 cams, it is VERY easy to see 122-125 hp, and 122-125 ft/lbs, on any honest dyno, tuned correctly, with that tame combination.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
#174
We do basically same build with 103 but with .630 cam and get 130/130 consistently. Makes for a fun ride
#175
I should be happy with the 123 lb/ft torque on my 14 CVO Limited, I have changed the mufflers to 2" Full Sac baffles and has removed quite a few decibles. Hopefully the torque won't suffer much, now if we could get some clear roads, warmer than below zero temps I could give it a run and see.
whocares (11-15-2017)
#177
#178
2009 CVO Road Glide
Fats Cats
T & T Master Tuner & Tune
Max Power. 93
Max Torque. 111
#179
About the same as my '15 CVO with 255s. 2" Fullsac baffle in the stock CVO cans.Also a TTS Tuner. Just a shade under 95 Hp and 114+ Tq. FWIW Doc did my tune,
#180
