CVO Slip-ons
CVO Slip-ons
I bought a pair of slip-ons, Part# 65583-11 & 65594-11, that came off a 2011 RG CVO. They had the heat shields on them with slotted tips. When I slipped the shields off, they didn't have the Scream'n Eagle logo on the side of them like I had seen on other slip-ons. Is this something Moco doesn't do anymore? Or is there a difference between CVO and Scream'n Eagle? They are also 3.5 inches Vs. 4 inches. Posted in Touring Section, got no response.
Thanks,
SugsPa
Thanks,
SugsPa
Thanks,
SugsPa
Thanks,
SugsPa
As far as Screaming Eagle pipes of yester years, they use to make a really good pipe, I think around 2003 or 2004. Those pipes were really good and good preformance as well.
May I suggest that you swap out the baffles in the 4" cans and install a fulsac preformance baffle. (choice of 1.75", 2" and 2.25" baffles.) The bigger the baffle, the louder they are. Just beaware that within time these baffles will get louder. Great sound and preformance for only $119 to $129, pending which ones you choose.
Those 4" cans look really good on a touring bike but the stock baffles are really a big joke. Very resticted and sound is not what a Harley should sound like.
Good Luck and Ride Safe!
YELLOWBIRD
I have a 2011 CVO RG Ultra (FLTRUSE). Came stock w/4" can. No Screaming Eagle on them anywhere. Played around and removed baffle pulled packing and put stock baffle back in. Little louder, still sounded like a washing machine. I was tired of playing so I purchased the 2.25" Rush Big Louie, a 4" slip on. With coupon found on the net. was $324 w/free ship from LeatherUp.com. You can use your stock end cap. I had removed the cat from the stock header and I'm running the Cobra Fi2000. Bike runs and sounds great.
Take a dremel tool and cut the welds inside the end of the muffler and with some work the baffle will come out. Modify the baffle or replace with ful-sac baffle.
Also, how does the baffle secure to the muffler, does it need to be welded?
Big Cith Thunder does not maike a baffle for the 4" CVO mufflers. You would need to gut the muffler and install the Big City Thunder part in the back of the headpipe just before it connects to the muffler.
As far as how the Fullsac baffle is secured, you drill one hole in the underside of the muffler and it secures the baffle with an allen bolt.
billygiles
Screamin Eagle CVO Models
13
06-03-2012 09:35 AM
