2013 FLHRSE5 Hydraulic Clutch Cable
I am in the same boat. This is what i have found from a few others.
Drag Specialties makes Hydraulic clutch hose adaptor.
Page 686 of the fat book. then you can use a standard Hydraulic clutch cable.
http://asset.lemansnet.com/static/si...ook/#?page=686
Hydraulic clutches use standard brake lines...you do need the above adapter for the OEM slave cylinder...but then you can order any length brake line you need for your apes.
What length did u end up getting?
Thanks for getting back to me.
9566874646 ask for valentine. Tell him Martin referred you. He will set you up or point you in the right direction.
