76 FLH Squeals Bad Starting
I have a 76 FLH that squeals terribly sometimes when I hit the electric start. After the initial squeal. it sounds normal and starts right up. I have changed the starter motor, and the starter shaft housing bearing, as well as the starter shaft bearing in the primary cover. I also replaced the starter housing plate with the oring because the round hole was way out of shape. It still squeals.
Could it be the starter clutch (bendix) that is squealing?
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
finally got around to changing the bendix today. as usual, you guys were right. no more squeal. sounds great when I use the electric start now.
chasing this problem down I replaced:
starter motor
starter shaft housing plate and bearing
primary bushing
oh well, it's fixed now, and now I know all those other things are good also.
starter motor
primary bushing
starter motor
primary bushing
starter motor
primary bushing
