76 FLH Fork Seals
76 FLH Fork Seals
probably obvious question here but the service manual diagram is not great.
I bought a James fork seal kit for my 76 FLH. I know where the large seals, spacer and snap rings go. l also know that the rubber seals go at the top under the caps. My question is about the paper gaskets. It seems clear that the large paper gaskets go inside the slider, at the bottom. Do the smaller paper gaskets go on the outside bottom of the fork sliders, where the nuts are at the bottom?
james copied the earley kits - if you have copper washers re use those instead
Received 3,220 Likes
Nope small paer gasket goes inside lower bushing damper tube
Never been able to stop my 49 froks from the occasional drip from the forks. Thinking of draining, cleaning, drying and maybe try some sealant. Just hate gooping **** up though.
Thanks for the help. I replaced the seals, using the paper gaskets in the James kit, refilled the forks with 7oz type B, corrected the length of the PVC spacer (it had too much preload, making the forks stiff), made sure the tighter wound portion of the progressive springs were at the top, and put it all back together.
No more leaks, and much better ride.
fadingfastsd
Shovelhead
13
04-03-2019 05:28 PM
