Shovelhead smokin'
Old 10-25-2014, 10:45 AM
marl's Avatar
marl
marl is offline
BTW......regarding head gaskets, some can appear to fit perfectly but can actually move a few mm when tightening the head bolts. This can result in the oil drain hole being partially blocked. I have bought some head gaskets where the oil hole is clearly not as big as the drain hole in the top of the cylinder. If you are very careful, you can open them a bit with a small, round file. But you will no doubt bur over the soft aluminium which is in the middle of the gasket. Removing the 'burred' edges of the newly enlarged hole can be difficult. Don't know why some companies make the hole in the gasket too small in the first place.
Old 10-25-2014, 01:51 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,054 Likes on 1,510 Posts
Originally Posted by marl
'74s don't have valve seals.They were only fitted to 1982-84 shovels as far as I know. '82-'84 models were also fitted with additional oil hosing from the tappet blocks to the base of the cylinders.
The additional plumbing at the Tappets is only on some [presumeably Califonia models]
Point is...No seal at all is still Not a Problem...No Smoking.
marl
Shovelhead
62
01-29-2020 06:46 PM
Iron_Kicker
Exhaust System Topics
05-25-2012 02:14 PM
Hey Zeus
Shovelhead
04-23-2011 12:16 AM
Rocketman69
EVO
45
05-17-2010 08:55 PM
72 chopper
Ironhead
11-18-2007 05:07 PM
Quick Reply: Shovelhead smokin'
