question about valve adjustments
Old 10-18-2014, 07:15 PM
cajun1957a's Avatar
cajun1957a
cajun1957a is offline
Default question about valve adjustments
I have posted about this once before and not really got an answer. When adjusting tappets its seems to be common practice to make sure the corresponding tappet wether it be exhaust or intake for it to be at its opposite. When one is at its lowest the other valve on the other cylinder is coming to its highest. Makes sence however i have noticed that there is no appreciable up and down movent of the lowest tappet for as much as 60 degrees of rotation or more. So my question is why not set that lowest tappet when its at the lowest regardless of the height of the other?
randy
Old 10-18-2014, 08:49 PM
MIKE93SVT's Avatar
MIKE93SVT
MIKE93SVT is offline
It's all the same. You just need the lifter to be on the base of the lobe. When one is open, the other is closed. That's why its explained that way
Mike
Old 10-18-2014, 09:38 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,048 Likes on 1,507 Posts
Sorry...I have Never [Ever] done it that way...Having Dragbikes, we always do it [valve adjustments] with the piston on the "power" stroke. ie. Both valves are closed and the piston is at about tdc.
Both valves should be closed at this time so...adjust them...then roll 'er over to the next cylinder...and do that one.
Course...I only been doing it this way for 30 years...maybe something has Changed!!!!
YMMV
Old 10-18-2014, 09:41 PM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 47,720 Likes on 18,538 Posts
There are several "correct" methods that can be followed. Some are "more correct" than others. Maybe this will help you. Pretty basic. Good Luck.
JustDave71
Engine Mechanical Topics
09-06-2023 06:32 PM
ScrapingFloorBoards
08-19-2016 05:15 AM
klaybus
Exhaust System Topics
03-07-2011 07:12 PM
Pixs
01-19-2009 05:32 AM
FNFLH
Shovelhead
10-06-2006 12:48 AM
Quick Reply: question about valve adjustments
