Crankcase pressure? Venting issue?
Old 10-21-2014, 04:31 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
oil leaks dont go away unless the oil tank is empty
Old 10-21-2014, 07:42 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,054 Likes on 1,510 Posts
True...But, If excessive blow-by is the culprit....It will be sufficient to reduce blow-by!
Unless something else is amiss!!!!
Old 10-21-2014, 08:03 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
and i thought i was answering - he has engine caes leaking and wanted to know if he should leave it as it might stop leaking with out doing anything
what do you think
Old 10-21-2014, 08:44 PM
Racepres's Avatar
Racepres
Racepres is offline
I think you are correct...in my initial read I saw oil escaping near the rear motor mount...and Assumed [bad word that one] crankcase vent.
On a re-read...between case halves sounds like a Tear-down to me also...My Bad.
Old 10-22-2014, 07:42 AM
streetglide99's Avatar
streetglide99
streetglide99 is offline
I pulled the bottom end out last night and I can see the leak below the rear motor mount at the case halves.its a small area where i cant see any sealant.looking in my manual it shows a few case diagrams. Ive done a few searches online but nothing has clear instructions.On this 69 can I pull the left case without stripping the whole cam chest? This will be my first time splitting cases. Or is this better left to a professional shop?
Old 10-22-2014, 05:50 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
the left side stays with the left case - right side, cam cover has to come off, oil pump and all the gearing has to be re timed - if you are mechanicaly proficient go for it if not its not very expensive to have someone split the cases and re glue it and give it back
Old 10-23-2014, 03:06 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Shovels can be as leak-free as any engine if assembled correctly, and maintained.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
baldy59
Shovelhead
06-24-2017 12:18 PM
ronnie41653
10-23-2013 08:48 AM
peted172
Shovelhead
05-19-2010 05:26 AM
Spur56
04-28-2010 04:09 PM
pontojr
Oil Archive (no new posts)
10-21-2005 11:03 AM
Quick Reply: Crankcase pressure? Venting issue?
