Static Timing Dyna S
Im going to try and static time the 1974 1200. With the timing mark in the inspection hole, I am going to rotate the plate until the plugs just fire. I may try with a test light across the coil as well. One thing I have noticed however is there is no counterweights under the Dyna S module. do these ignitions modules not use an advance or do I not need to worry about it given im using the advance mark?
randy
randy
That is Correct. Remember you are trying to set the timing at Full Advance [hence the advance mark] Right!
Just Like Points...
Edit; Remember that once "fired" you may need to move the pickup a ways away from the Rotor to "Reset" the iggy.
I always start with the plate at Wayyyy too much Retard, and bring it Back to Fire.
But, Cycling the Ignition switch [or kill] will generally get you there [reset] also.
randy
randy
Just noticed this part....The Dyna S uses the mechanical advance unit...Just Like Points.
The Dyna S is effectively Electronic Points!!!!
EDIT; Maybe this will be helpful.
Not trying to be a Dick, nor condescending here...Some folks know this..and some don't, anothers...Prolly Forgot!!!
