Best ignition for kicker
Hell so does Points if ya get too low!!!!
Ive experienced this a couple times. Once with points it went so dead that the motor would shut off when I pushed on the brake. The other time was with a dyna and the bike just ran like crap.
I did have trouble with a dyna S that would die on me about an hour from home. After a while it was twenty minutes. I thought I had a fuel problem because id pull the carb right on the side of the road and clean it out then it would start. Later on I realized that by the time I cleaned the carb the ignition would cool down enough to start it again. Anyway, it was the ignition and after I put some points in it that never happened again.
I can't get enough miles on it for a good test because its so cold. I put on a new dyna 5 ohm coil, because it had a 3 ohm coil on it. I'm happy to know it has the right one now, even if it doesn't turn out to completely solve the problem. If it continues to have a problem, I can either put the points back on it or just replace the dyna s. I'm pretty sure dynatek would test the dyna s for me if I sent it in to them.
The electronic ignition module on my 1984 Softail died suddenly in 1995. I was unwilling to pay the exorbitant price for the "upgraded" module then available, so I bought a Blue Streak points conversion kit. I was so pleased with the performance of the points that I never changed them. I ran the same set for 9 years.
I am currently rebuilding my Softail and have a brand new points kits waiting to be installed.
> I can repair/replace a set of points in minutes
>They never just fail unexpectedly as electronic units can/do
>They do not overheat or send me on wild ghost hunts.
>I can keep a new set of points in my tool bag.
>I am more than pleased with the performance so I see no need to replace them.
There are just some things that I want to remain primitive. Carburetors work and I can fix them when they begin to fail. Point and condensers work and I can fix them when they fail. Chains work and I can replace them in minutes when they wear out. I have yet to have one fail even when long past it's service life. Kick starters work and I can repair them when they wear out.
BTW, the 1985 FXWG is one of my favorite Harleys. They really got it right that year.
