1978 FXS- Gonna keep it stock
I've owned this FXS since 1984. Previous owner had swapped the original exhaust for the "oh, so common" drag pipes. He also replaced the original rear fender with what appears to be from a Wide Glide.
So, I haven't started the thing in over 20 years and it has been garaged the entire time. Gas was drained from the tanks and carb. Also dumped oil into the top of the cylinders through the spark plug holes. That's about all I did to it during the last winter storage prep.
The plan I had was to mod it to sorta like an FLH. I have finally decided to keep it original as the correct look FXS. With the exception of the exhaust and the rear fender it's all original in very good to excellent condition. Miles are at 25k.
So, I'm searching online for pictures of so called "original" early 1978 FXS's and what I see is pretty straight-forward except when I get to the handlebars. I'm seeing a few different styles. The set on my bike are what I think are referred to as "buckhorn" handlebars. Can anybody verify if these would be the correct style factory handlebars?
I'm sorry I don't have any pictures to post right now, but hopefully will have some posted in a few days.
I know it's gonna take a lot of work to get it back to good, but thankfully I have the means to see it through.
I posted in the "wanted to buy" section, but thought I would ask here as well. I know they are hard to find, but I am looking for an OEM exhaust pipe, 2 into 1. If anybody has one or may have a lead on one, I would be grateful if you could let me know. Thank you and kind regards-
I.M.
I.M.
FXS fender rails are different in appearance than FX rails. They have black inserts that show through the stock sissy bar. The stock handlebars are the flat drag style which most people changed for a more comfortable set. If your's have been changed you will also have to shorten the control wires back to stock length. The risers are a pull back style for the drag bars.
Thanks for the replies, Guys.
@Tom- Thanks for the link to the exhaust. After finding the correct part number I was able to find a few more for sale.
@ Racepres- Thank you for the fender link. I'm gonna need to get serious and get a parts manual or use that web site in the "sticky" section of the main page. Also, great catch on the fender rails. I was assuming the current ones would work.
@ Filthy- thanks. Your mentioning of the cut-outs or inserts in the fender rails caused me to relook some pics and, of course, you are correct- they are different. As for the handlebars, I have seen the straight drag type in pics. Cool look but probably not too comfortable for distance. That's what my Road King is for! Good points on the cables, etc. it has the 4" risers swept back.
Soooooo, it's looking like there is more that needs to be replaced than I originally thought. Thank you all again. I will try to get the pics posted within the next few days. Take care-
I.M.
I.M.
I personally don't care for the "indented" ones..Correct or Not!
