Andrews A vs AB ?
Andrews A vs AB ?
Does anyone have experience with Andrews A and AB grinds on a light shovel?
The difference is: A has the same intake/exhaust duration, AB has longer exhaust duration.
some places say AB makes a shovel run cooler, some say it calls for higher RPM.
I'd guess it is both, so my question is: is it noticeably cooler or noticeably higher RPM (again, we are talking a light FXR here)?
While it likes RPM I'm not sure it is that noticeable.I can't say that you can "feel" a temperature difference either..I have run it...But, For the Shovelhead, Most cams require lots of RPM in order to tell the difference...I don't ride My Shovel that way. The FLH [H Grind] works just fine for me...
I can say I like the AB better than the "B" but, that ain't sayin much...
Gonna try a 300 soon...But, I'm a glutton for punishment!!!
i perfer the AB over the A and both will use hyd or solid lifters
it stands to reason about the longer exhaust timing to reduce oil temps, but we are talking 5 to 10 dregees only so it yea BUT no, in that it actually is changing the dynamics of the running of the engine one could say as they have it does
having said that it does pull different and i like the spot it does it in
Well i have a shop and do not work on twinkies evo is the last harley we take in the shop
shop winter jobs -- 1950 original pan - took everything not 1950 off and found all oem 1950 to go back on -- including top end over haul
1960 Pan chopper correct motor all matching in a 1952 hardtail frame, chopper not neck cut 6 over springer - complete motor IE stroker 4 1/2 stroke cam solide kind of thing / trans overhaul re fresh FX gearing light bike - re do wiring - re do star hubs nice ride really
carry in 1965 pan motor complete over haul cam solids another chopper / bobber kind of thing looked at trans today will be doing it as well
1966 FLH - complete motor / trans - complete new wire harness - wheels - forks - swingarm - over hauled its a driver -
1972 Shovel motor stroker screw up --- by another shop cant go into it lets just say it had 30 miles and seized as they mixed up the pinion shaft that is side oil with a end oil cam cover and it destroyed all of the new stuff in it - shame really took it apart and still dident know what happened --so
1977 shovel motor and trans overhaul it was time -- one of my bikes dresser it looks like it did when it left harley
another one of mine stripped to the screws - 1981 FLT shovel shark nose its an original 16,000 mile bike just making it real right for anther 30,000 miles
evo 96 inch stroker we did its in for a dyno tune and look for a little more -- always a little more hahahahahahaha
my pride and joy 1948 Indian Chief red as original as can happen re freshing the motor and trans it should last me the rest of my life ready in the spring - when it did not want to start i knew exactly how it felt as we are 5 / 6 weeks different in age by chassis number build date - hahahahaha
chassis up resto on a very low number 1946 Indian Chief complete bike we spend 17.000 so far and only have maybe 1/2 what we need
the 77 its a bolt in but we always do the heads when we cam them but thats me as i have a rymac maching to set the valve spring location and pressures ( hyd lifters ) so they dont pump out at 4000 RPMs and all the power goes away
i have some pictures i was just going to post of the bikes if it will let me that is - i still have a rotary phone in the shop
late 1980 / early 1981 and they were different both years with different guides they were the same length one had seals and one did not
funny thing was you had to take the heads off to see what ones it had as they haphazard the engine installs so what was done to one got lost in the mix of all of them for assembly
it was stupid really - but once the guides are replaced it is all good
When the head is off how do you tell? Would love to put a Leinweber L3S in my bike.
Thanks,
Dave
