little black buttons in old style shovelhead controls
does anyone know how to attach those little black buttons on the switch housings on 70's shovelheads? i bought new bars, extended harness and all in a kit, but the buttons are a mystery to get them to attach to the little posts... any help guys?
Received 4,916 Likes
Note that if you glue them the end will probably be broken off the switch if they are removed again...Possibly what has already happened.
If you look closely, the switch has a Smaller [slightly] end on the post, this has a Kind of a **** on it...the Little button extension should snap over that "button"...sometimes you gotta push pretty hard.
And sometimes the switch has been broken, and the button extension must be glued in place....
Finding quality replacement switches, and getting them soldered in place without damage, can be a Challenge...Best try to find someone who has done it before...or Buy lots and practice...
One thing..they do Not need as much heat as some think and the buttons are much easier to solder [correctly] than the damn switches...
Finally make sure the wire ends are not too long and well "tinned"
Good luck
Good luck
flt04lee
08-22-2006 09:52 PM
