Screamin Eagle 7 pin ignition module on a 72 Shovel
Hello and thank you for being here... Wherever "here" is for you...
The name is David, I'm from Caracas, Venezuela (lately called the last place before hell). I'm the owner of a nice little 1972, 74", 4spd. Pretty much stock as an occasional driver...
I've got some issues lately I need to work out with it, but first things first...
I'm installing a Screamin Eagle ignition module. The markings on the module are: 32597-96, 6800 RPM, 9611 and REV* (number or letter not clear) but I can't seem to find information with exact color matches and/or a diagram for what I have to be able to install it.
The connector is a 7 pin plug.
The top 3 pins are PINK - WHITE - BLK/WHT
The bottom 4 are BLACK- PPL/WHT - GREEN - RED
I can figure that the GREEN, RED and BLACK go to the same colors coming from the sensor (pick-up), the PINK I'm guessing RPM and the PURPLE/WHITE I'm thinking VOES (or maybe backwards but neither will be used)... but the other two, the WHITE and the BLACK/WHITE I'm confused.
Any help would be appreciated.
Till next time.
Till next time.
PINK wire to IGNITION COIL, NEG TERMINAL
WHT wire to IGNITION COIL, POS TERMINAL
BLK/WHT wire to IGNITION SENSOR PLATE, BLK CONNECTOR
GREEN wire to , GRN CONNECTOR
RED wire to IGNITION SENSOR PLATE, RED CONNECTOR
VIOLET/WHT wire to VOES switch
BLK wire to FRAME or BATT GROUND
positive wire from the ignition switch connects to positive on the coil
Wrencharound
10-30-2017 07:33 PM
