front brake noise
Old 02-24-2015, 06:31 AM
cajun1957a's Avatar
cajun1957a
cajun1957a is offline
Default front brake noise
1974 flh...... Ever since i replaced the front calipur there is a strange noise when applying the brake. its not a metalic sound but an odd rubbing sound more like when rub something soft on a hard surface. like when you rub a highly pollished surface with a wet hand. a dragging sound. Not a squeak but a low decible squeak if that makes sence. The shoes are fine, the disk is ok and not scoring. just an annoying rubbing sound.
randy
Old 02-24-2015, 08:44 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,054 Likes on 1,510 Posts
Are the pads "matched" to your Rotor material??
Metallic pads against a Cast rotor make a Noise, and ruin rotors too.
Old 02-24-2015, 09:35 AM
V_twins's Avatar
V_twins
V_twins is offline
Thant's a good point... I knew about specific pads for specific rotors but and premature wearing or brakes not working as they should, but didn't think about the noise
Is there a chart or something somewhere saying what pads go on what rotors?
I looked online but could not find specific info.
What pads to use for zinc, stainless and chrome rotors?
Old 02-24-2015, 10:15 AM
Racepres's Avatar
Racepres
Racepres is offline
I don't know of such a Reference.
I basically try to stay with O.E. so...No Problems.
Lots of Folks [Racers included] using Lyndall's pads...especially with OE [Cast] Rotors.
I Have No Experience with them Either...Big Help Huh???
My "Thing" is to avoid Metallic pads altogether, and So Far...No Problems.
Note; I am Not a Road Racer.....
Old 02-24-2015, 11:12 AM
cajun1957a's Avatar
cajun1957a
The pads are off the caliper I had originally on the bike. I replaced the caliper with an identical one that I had floating around. Same disk, same pads, same style of banana caliper etc etc. There is vertically no wear on those pads or rotor. No scoring etc. It was an identical caliper swap out. And its only if I push or roll the bike and use the brake it happens. However I noticed that there is a slight movement in the caliper when applying the brake. It is held together with bolts on a pin at the top. Im wondering if that pin is sloppy and the pads are vibrating a little when applied. I don't know if that would be an issue but these are 1974 parts and subject to age.
randy
Old 02-24-2015, 11:50 AM
Racepres's Avatar
Racepres
Racepres is offline
What is happening is the caliper you put on is not in exactly the same orientation as the one you took off...the pads are worn parallel to the old caliper, but, not to the new one...It will probably correct itself with wear and use...if it is not too far off.
Old 02-24-2015, 01:26 PM
pjb's Avatar
pjb
pjb is offline
I was missing the anti-rattle clip, but that's probably not the sound you are having.
Old 02-24-2015, 03:04 PM
cajun1957a's Avatar
cajun1957a
Racepres that makes a lot of sense. I was going to replace it with a newer type of caliper but up here in Canada, you need a mortgage to buy parts like that. So I will live with it for now. What would you recommend as a replacement caliper should I win the lottery?
randy
Old 02-24-2015, 08:20 PM
SeaZund's Avatar
SeaZund
SeaZund is offline
new disc pads need to be "bedded" to the rotor
Old 02-24-2015, 08:25 PM
Racepres's Avatar
Racepres
Racepres is offline
randy
Oh Hell!!! I still run the Banana!
I do own a Late model set of Forks with a 2001+ Caliper...I just can't bring myself to put it on my '74!!
I been using this old Crap for so long that I think it is OK...
Was your Bike Mine...I would Mash the Brakes at every opportunity that my Mates would not think I have Somehow Lost It...If it gets It's **** Together...Cool, If Not...Next Swap Meet...I'll Find a NOS O.E. Set of pads...Heck...Since they suck so Bad...I will get them for a Song!!!!
Ride it My Friend...don't analyze it....Ride it.
bluzman24
10-31-2017 10:17 PM
89richard
03-02-2017 12:41 AM
easttnrhino
07-23-2014 11:32 AM
RocketRocker
12-07-2009 05:20 PM
lowleveldriver
08-28-2006 11:07 AM
Quick Reply: front brake noise
