WTF...Just happened...?
Old 03-04-2015, 10:56 PM
ROTTEN ROB's Avatar
ROTTEN ROB
ROTTEN ROB is offline
Default WTF...Just happened...?
76 FLH,4 speed tranny. Decided to go for a putt a few days ago...Fired her up,did the usual warm up...sit on my stool,have a smoke while she's warming up.Gave a little twist of the throttle....half way down on the RPM'S, she lurched forward.I caught her before she fell...Died of course...Fired her back up,backed out of the shed,a trail of tranny fluid followed......She now has a 1 inch crack on the bottom of tranny.Stress fracture; or did the tranny let loose...?
Old 03-04-2015, 11:17 PM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,201 Likes on 1,478 Posts
1 in ch crack on the bottom of the tranny....pics would help.
Along studs for mounting, along mainsshaft? What you are giving here is pretty vague.
If you take out the primary chain, will the motor turn over.
Bike lurched forward because 'something' seized or 'locked up'. Figure that out and you have probably isolated the problem.
Old 03-04-2015, 11:32 PM
ROTTEN ROB's Avatar
ROTTEN ROB
panz..along main shaft, belt drive,it fired back up.Did not pop it in gear.In neutral,motor hums.............Overnight...pan underneath tranny ,it's dry....
Old 03-05-2015, 08:53 AM
panz4ever's Avatar
panz4ever
Don't think I would try to start it again without pulling the tranny, popping the lid and see what's going on. Maybe you chipped a gear, it fell off and got jammed initially in the gear set? Purely speculation though.
At any rate you need to take the gears out and have the box welded. That crack is not going to get any better, especially around the mainshaft.
Old 03-05-2015, 06:41 PM
ROTTEN ROB's Avatar
ROTTEN ROB
Thanks panz...just wanted a second opinion before the tear down...........
Old 03-06-2015, 09:09 AM
panz4ever's Avatar
panz4ever
Best place to get the tranny case repaired is Creekside Welding and Machining. Used them to repair my 49 heads and used them to fix the bottom of the tranny case.
Tranny case ...before. That corner had actually broken off and needless to say the stud fell out as well as all the oil in the case
After... can hardly tell it was ever repaired. There is just a slight color difference between the aluminum metals
Probably not the cheapest, but they are fair-priced, will give you and honest evaluation and turn around is reasonable.
Not sure if you have ever seen it but SuperCycle 1980 had an entire article on tearing down the tranny. I actually have the rag and dwonloaded a .pdf version I found elsewhere. If interested I can email you a copy if you send me your email address. O
Or, not sure what part of Kali you are in (POZO), but if near the Bay Area I can get it to you (advantage of retirement).
Old 03-06-2015, 05:48 PM
ROTTEN ROB's Avatar
ROTTEN ROB
I'm thinking of just swapping it out with a kicker 4 speed, a brother I know has for cheap and a little trade.............As for where is POZO...It's about 25 miles North-East of San Luis Obispo Cali. Later... ROTTEN ROB..........
Old 03-07-2015, 08:07 AM
glidein wide's Avatar
glidein wide
glidein wide is offline
Wish I could help on this one, however I am curious what caused it. Post your findings would be appreciated.
Best of luck
Aircooled81
18
01-13-2019 06:23 PM
L0LIF 67
10-05-2013 10:50 AM
paguy
07-30-2010 07:15 PM
elevenbravo78
EVO
08-11-2009 02:21 PM
harris48cars
07-26-2007 09:46 AM
Quick Reply: WTF...Just happened...?
