Evo ignition on a Shovelhead
Just wondering if anyone put the evolution ignition kit that Harley Davidson used to sell on their shovelhead. I put one on my '78 shovel about 20 years ago. No problems since. I did not hook up the voes and wonder if their is any advantage to doing so. Thought this would be a good place to ask.
Received 3,210 Likes
Started in 84..all evos had voes...since he is using an evo ignition, all he has to do is hook up the violet wire and a vacuum hose to the voes switch...the advantage would be you could run more timing without pre-ignition...better throttle response and gas mileage.
As far as the ignition...I like them...The Eldest has been running a Late Ignition on his '75 Sportster for Years.
I ran a Sportster "box" on my FXR until it **** the Bed...
I would absolutely run one again...I would also run a VOES as stated, you can give 'er more advance. Nothing to putting a Vacuum line in I got a Spacer block with one.
Unhooking [un plugging] a voes leaves an intake leak...one bad enough to effect how the thing runs...Ignoring what the engine is trying too tell ya, is a Problem waiting to have a Bad end.
Can't scare Me...I like the way the VOES works on a Street bike...
