New to me 1982 FXR, questions
Old 03-19-2015, 08:41 AM
atengnr's Avatar
atengnr
atengnr is offline
Default New to me 1982 FXR, questions
Hello again all. Purchased 1982 FXR, dont have bike in my possession yet, but have a question. Bike has ignition switch on the tank console (it appears bike has fatbob tanks), but owner has no key. I wanted to order a new ignition switch ASAP. Does anyone know what switch would be correct? It is the chrome switch with the lid that flips open to expose the key slot. Are all of these switches similar?
Thanks.
Old 03-19-2015, 09:09 AM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,408 Likes on 879 Posts
why not get a key made for your switch? locksmith or dealer can do it...
Old 03-19-2015, 09:13 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,050 Likes on 1,508 Posts
Thanks.
The one you have is Not Correct for an FXR.
The FXR keyswitch is located under the tank on the left side, just behind the petcock!
Old 03-19-2015, 09:49 AM
atengnr's Avatar
atengnr
atengnr is offline
Default Brake Fluid
Unrelated question. Can I run Dot 5 fluid in this bike? Thanks.
Old 03-19-2015, 10:56 AM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
hard question to answer w.o. knowing what's there now. DOT 5 was not stock so you can't w.o. completely flushing the system. BUT if a PO did that already you can.
DOT 3 & 4 dissolve in water, DOT 5 doesn't. Put a few drops from your m.c. in a shot glass of water, shake well, and see what happens.
Old 03-19-2015, 11:29 AM
V_twins's Avatar
V_twins
V_twins is offline
DOT5 IS stock for those bikes
Ask PO what he used
Ignition swith not OEM,. Does it flip open to the side or to the back?
Old 03-19-2015, 03:22 PM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
I guess my memory is shot - thought my 1982 used the old stuff.
Regardless, you never know what is in an old bike without actually checking it...
Old 03-19-2015, 04:58 PM
atengnr's Avatar
atengnr
atengnr is offline
Ask PO what he used
It opens to the side. Thanks alot.
Old 03-20-2015, 10:35 AM
V_twins's Avatar
V_twins
V_twins is offline
If it opens to the side it's a newer swith.
I don't know much about those, buy a buddy had an early Road King twin cam and the switch opened to the side
Old 03-21-2015, 05:55 PM
atengnr's Avatar
atengnr
atengnr is offline
Actually the lock opens upward.
Quick Reply: New to me 1982 FXR, questions
