1200 FL with S&S "B" problem.
Old 04-07-2015, 12:19 PM
David "Lone-Wolf" Lubowski's Avatar
David "Lone-Wolf" Lubowski is offline
6th Gear
Default 1200 FL with S&S "B" problem.
It's a '72 1200 with an S&S super "B".
The bike used to run beautifull, from one day to the next after I cut the choke, the bike coughs and dies.
it has a 28 intermediate and a 66 main.
The manifold is O-ring type, but have checked for air leaks and nothing... Changed the O-rings and the clamps but to no avail... Changed carbs to a butterfly Keihin, and the same. Changed to a Keihin CV, and still.
Also checked head bolts and re-torqued to specs. Solid lifters adjusted.
This is getting rather frustrating...
Old 04-07-2015, 01:02 PM
pjb's Avatar
pjb
pjb is offline
ignition tune up time?
Old 04-07-2015, 01:22 PM
OHIOCAFERACER's Avatar
OHIOCAFERACER
OHIOCAFERACER is offline
Yep.....sounds like a spark issue.
Old 04-07-2015, 02:44 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,054 Likes on 1,510 Posts
If points...it needs a condenser, at least.
If electronic iggy...and kick start, it needs a battery.
If it fires up with e-start...IDK....Broken Maybe? But, I think Intake leak....
Old 04-07-2015, 03:59 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
you cant trust the gas we get in your country or mine sooo - remove the 2 jets and clean them very good blow them out with air, and look into the ends you should be able to see right through the center when you first remove them - clean and see if they look bigger inside if so that was it
Old 04-07-2015, 05:47 PM
6th Gear
New plugs, same. old clean plugs, same. New plug wires, same. Changed coil, same. Changed to electronic ignition, same. Changed pick-up, same... Don't think it's ignition...
Old 04-07-2015, 06:00 PM
6th Gear
I've cleaned the carb and blew air out every orifice (of the carb... )
The jets are sparkling clean. I clean them with carb cleaner and finish them off by a good soak in solvent (paint thinner) and run cotton thread just in case... I've even used the jet brushes and still the same.
Fuel here in Venezuela is the pits, so I have a large clear filter to see when it's getting dirty, and/or when there is water in it...
To clear up a bit more. It starts like a beauty and warms up fine with the choke pulled. I drop the choke 1/2 way and runs fine... but when I drop it all the way, the bike puffs, coughs, spits and dies.
Old 04-07-2015, 06:19 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,547 Likes on 3,057 Posts
After all this, throw a 29.5 intermediate in and see what happens.
Old 04-07-2015, 07:35 PM
Racepres's Avatar
Racepres
Racepres is offline
I wouldn't run an inline filter...I would ensure the in tank filter is Clean and proper.
After changing carbs 3 or 4 times...I guess I assume the carbs are jetted at least close for a Shovel...But...
I'm gonna go with Stiggy, and wonder what jets you are using???
Old 04-07-2015, 07:50 PM
pjb's Avatar
pjb
pjb is offline
sounds like a big intake air leak
Quick Reply: 1200 FL with S&S "B" problem.
